deka kinkeshi and larger UNDER CONSTRUCTION
91 replies to this topic
#1 89cpe
89cpe
    sweep the leg
  • 1510 posts
Posted 04 January 2011 - 10:24 PM
This thread will be dedicated to deka, sd deka, the 5" , great muscle and anything else of that size range. i have been doing alot of research and comparing everything that i have to make what i think will be the most accurate and detailed deka kinkeshi, the slightly larger kinkeshi and the great kinkeshi list.
i will touch base on the different packaging, markings, variances, paired figures, bootlegs and share my facts and theories along with some help from you guys.
any pictures you have please send to ryantwo40@hotmail.com
i will be using some info and pics already shared on this forum and naochins and some other sites
Size comparison
Attached File  4inchKinkeshi1.jpg   38.22K   145 downloads
Here are some deka still connected to their tree
Attached File  dekatree.jpg   22.71K   166 downloads
original deka in single packaging
Attached File  bigf.jpg   93.26K   147 downloads
Attached File  4package.jpg   31.88K   119 downloads
Attached File  diff4inpackage.jpg   58.91K   106 downloads
Attached File  4inch2pack.jpg   25.91K   108 downloads
Paired figures in packaging
Attached File  4inchpairedcarded.jpg   49.39K   150 downloads
Here are some examples of the deka kinkeshi 10 packs. there are 10 boxes in all making the full original set and then there is the later part 11 that I'm not sure if came in a boxed set or only as singles
Attached File  IMG_4037.JPG   23.49K   105 downloads set 2
Attached File  4inch3.jpg   45.68K   174 downloads set 3
Attached File  4inch4.jpg   44.06K   139 downloads set 4
Attached File  4inch6.jpg   76.86K   106 downloads set 6
Attached File  4inch7.jpg   58.83K   109 downloads set 7
Attached File  4inch8.jpg   54.99K   133 downloads set 8
This is an ashuraman variance, which is very similar to the original one. not sure what set he belongs to maybe a later alternate or some sub set.
Attached File  IMG_1594.JPG   161.29K   138 downloads
Here are examples of positioning variances, there are some found in the single packaging
Attached File  IMG_1593.JPG   178.14K   119 downloads
Here are examples of paired figures which are not part of the original set. but just like the original set the earlier are marked with a - and the later with a / They also have letters on them which i assume is to pair them up.
Attached File  IMG_1588.JPG   156.75K   106 downloads
Attached File  IMG_1590.JPG   162.22K   92 downloads
Attached File  IMG_1591.JPG   175.03K   112 downloads
Here are a few of the reissue. down below is an example of the stamp. they are made of a different plastic which is glossy and slightly harder
Attached File  IMG_1595.JPG   178.79K   117 downloads
Attached File  IMG_1597.JPG   106.4K   112 downloads
here is a gitd reissue
Attached File  IMG_1598.JPG   159K   119 downloads
colored deka in package
Attached File  dekacolor22.jpg   23.83K   103 downloads
Attached File  fouryellow.jpg   23.93K   105 downloads
here is a link to the battle royal set http://ulala69.web.i...battleroyal.htm
this was also mentioned here and was said to not have any unique sculpts. but as far as i can tell the 6 in the top picture are unique sculpts. they are slightly larger than the deka kinkeshi.
Attached File  BattleRoyalKinkeshi.jpg   56.49K   116 downloads
Here are some pictures of 4" bootlegs.
http://ulala69.hp.in...pachidaishi.htm
Attached File  BootlegKinkeshi.jpg   53.77K   87 downloads
Attached File  IMG_1592.JPG   169.12K   79 downloads
These two are examples of deka bootleg thumb wrestlers. I got them in a hobby store when i was a kid. they are made of a harder plastic
Attached File  IMG_1599.JPG   187.68K   73 downloads
Attached File  IMG_1600.JPG   197.66K   84 downloads
Here are examples of larger kinkeshi. not sure what theyre called and little is known about these at this point. they are larger than the 4" but not as large as the great kinkeshi. all 3 of the figures i own have different stamps so i would say that all 3 are from a different series. update: i recently found that some are from the battle royal set
Attached File  IMG_1585.JPG   222.78K   78 downloads
Attached File  IMG_1603.JPG   199.49K   79 downloads
Attached File  IMG_1604.JPG   136.78K   61 downloads
Attached File  IMG_1605.JPG   137.98K   42 downloads
Attached File  IMG_1606.JPG   121.99K   48 downloads
Attached File  larger6inch.jpg   19.07K   50 downloads
larger bootlegs no markings
Attached File  IMG_1607.JPG   193.93K   73 downloads
Here are examples of the great kinkeshi. there are 30 in the set and 2 pairs of paired figures
the link below has a section where you can find more pictures and info on these
http://translate.goo...emia/index.html
example of 8" packaged
Attached File  8bull.jpg   40.57K   68 downloads
example of 8" paired figure
Attached File  paired 4 inch box.jpg   33.92K   57 downloads
Attached File  IMG_1608.JPG   182.16K   55 downloads
the stamp
Attached File  IMG_1609.JPG   111.63K   81 downloads
Attached File  OverSizedKinkeshi2.jpg   53.61K   105 downloads
Attached File  OverSizedKinkeshi.jpg   59.15K   114 downloads
Attached File  OverSizedKinkeshi4.jpg   32.6K   117 downloads
This is an example of an articulated kinkeshi. its not quite 4 inch but i felt it deserved to be a part of this thread. i dont know anything about these at this point other than there are a several different sculpts that ive seen on yahoo japan
Attached File  IMG_1601.JPG   173.72K   89 downloads
Attached File  IMG_1602.JPG   172.72K   58 downloads
Edited by 89cpe, 26 May 2012 - 02:33 PM.
#2 89cpe
89cpe
    sweep the leg
  • 1510 posts
Posted 06 January 2011 - 08:04 PM
Deka kinkeshi checklist from naochins site. I filled in his blanks.
Attached File  IMG_1625.PNG   640.2K   187 downloads
Attached File  IMG_1626.PNG   570K   205 downloads
Attached File  IMG_1627.PNG   576.97K   171 downloads
Attached File  IMG_1628.PNG   558.66K   141 downloads
Attached File  IMG_1629.PNG   559.04K   121 downloads
Attached File  IMG_1630.PNG   556.29K   123 downloads
Attached File  IMG_1631.PNG   559.44K   121 downloads
Attached File  IMG_1632.PNG   551.43K   132 downloads
Attached File  IMG_1633.PNG   442.45K   150 downloads
Attached File  IMG_1634.PNG   294.58K   157 downloads
Attached File  IMG_1635.PNG   495.69K   203 downloads
Attached File  IMG_1636.PNG   342.04K   152 downloads
Variance checklist ??? incomplete
Attached File  IMG_1646.JPG   15.77K   100 downloads
Attached File  IMG_1647.JPG   17.99K   60 downloads
Attached File  IMG_1648.JPG   15.85K   33 downloads
Attached File  IMG_1649.JPG   15.72K   30 downloads
Attached File  IMG_1650.JPG   17.05K   18 downloads
Edited by 89cpe, 26 May 2012 - 02:34 PM.
#3 Ericnilla
Posted 07 January 2011 - 01:33 AM
Very cool Ryan, and much appreciated. :)
hopefully i can help some more with pics.
#4 89cpe
89cpe
    sweep the leg
  • 1510 posts
Posted 13 January 2011 - 02:49 AM
updated with more info and pictures. please if you have any of the stuff in this thread go through and see if theres anything you have that is not pictured. ex variances or sculpts that are missing all together thanks
#5 NamaNiku
Posted 13 January 2011 - 07:46 PM
Great work brother! (read in Hulk Hogan voice)
#6 89cpe
89cpe
    sweep the leg
  • 1510 posts
Posted 13 January 2011 - 08:54 PM
Haha thank you
#7 fuzzbuster
fuzzbuster
    Yes
  • 2322 posts
Posted 14 January 2011 - 04:33 AM
This is coming along nicely. Excellent work, 89cpe!
#8 Ericnilla
Posted 04 February 2011 - 12:38 AM
4" SD Kinkeshi figure set
Packaging
Attached File  SD kinkeshi 4 inch 01.jpg   63.48K   43 downloadsAttached File  SD kinkeshi 4 inch 02.jpg   67.38K   44 downloads
Front and back with size comparison
Attached File  SD kinkeshi 4 inch 03.jpg   40.45K   36 downloadsAttached File  SD kinkeshi 4 inch 04.jpg   43.68K   43 downloadsAttached File  SD kinkeshi 4 inch 05.jpg   53.47K   63 downloads
Insert with checklist
Attached File  SD kinkeshi 4 inch 06.jpg   35.01K   60 downloadsAttached File  SD kinkeshi 4 inch 07.jpg   59.17K   61 downloadsAttached File  SD kinkeshi 4 inch 08.jpg   28.12K   61 downloads
#9 NamaNiku
Posted 12 February 2011 - 12:22 PM
Kinnikuman "Great Muscles"
The Sunshine fig is only priced at 1,890円 :thumbsup:
Edited by uoozuman, 12 February 2011 - 12:27 PM.
#10 TOPHER
TOPHER
    Chit Happens.
  • 1228 posts
  • Interests:My Recording Studio, Video Games, Shelby Cobras, M.U.S.C.L.E., Battle/Laser/Greek Beasts, MIMP+WIMP, Remco Mini Mashers, Figurines holding any kind of musical instrument, Weird Ball Wrestlers......
Posted 12 February 2011 - 02:12 PM
Ay Ryan,great topic,nice work. :thumbsup: ,thanks.
I totally forgot I had a couple of these.
'On Sale' or 'For Sale'. It's really the same thing! The word, 'Sale' means YOU CAN BUY IT,
not that it is discounted. We as consumers are conditioned to think"On Sale"means it's cheaper.
#11 TheOrgg
Posted 12 February 2011 - 05:29 PM
The names of most of those are kinda messed up. Doctor Bombe and Kinkotsuman expecially jumpped out.
Also, anyone have a Kinkotsuman (Skeleton with the gun) they'll part with? I've been looking for one of those for a while.
#12 TOPHER
TOPHER
    Chit Happens.
  • 1228 posts
Posted 12 February 2011 - 06:11 PM
Nope,no Skeletons in my closet. :lol: :lol: .
#13 89cpe
89cpe
    sweep the leg
  • 1510 posts
Posted 13 February 2011 - 12:40 AM
I have about 5 or so... So yeah sure
Wheres sunshine for that price!?!?!?!?!
#14 NamaNiku
Posted 13 February 2011 - 08:20 AM
Yup spoke with Miyakoshi at Mandarake - all three in stock still
#15 89cpe
89cpe
    sweep the leg
  • 1510 posts
Posted 14 February 2011 - 09:18 PM
Got the sunshine! Thanks!!!
#16 NamaNiku
Posted 14 February 2011 - 09:20 PM
Very cool! I have not really seen that one before. You have a pic of a similar one on this thread, but the head sculpt looks different from the one posted by Mandarake.
#17 89cpe
89cpe
    sweep the leg
  • 1510 posts
Posted 14 February 2011 - 09:29 PM
I just got a weird 6" one too in a lot thats really unique
#18 Khaniku
Khaniku
  • 14 posts
Posted 27 February 2011 - 01:29 AM
hi here are my Large kinkeshi collection.
I love them.
#19 89cpe
89cpe
    sweep the leg
  • 1510 posts
Posted 27 February 2011 - 09:32 PM
Awesome! Im making a checklist for those so check back to see which ones you still need ;)
Edited by 89cpe, 27 February 2011 - 09:38 PM.
#20 Stinger Wolf
Stinger Wolf
    Kinnikuman
  • 180 posts
  • Interests:OMega キン肉マン fan/collector since 1983...
Posted 07 April 2011 - 01:58 PM
Deka Kinkeshi list
Edited by Stinger Wolf, 08 April 2011 - 10:34 PM.
#21 Ericnilla
Posted 07 April 2011 - 02:17 PM
Very cool list. Never seen that before. where did you get it~?
i notice it is missing one part.
#22 Stinger Wolf
Stinger Wolf
    Kinnikuman
  • 180 posts
Posted 07 April 2011 - 02:39 PM
Oh, I got it back in the day. Mid 80's. Unfortunately I sold most of my Deka and I can't remember which one I had that it came with. I have other Deka lists. I just have to dig them out one of these days to see if I have the missing one.
Edited by Stinger Wolf, 08 April 2011 - 10:30 PM.
#23 Stinger Wolf
Stinger Wolf
    Kinnikuman
  • 180 posts
Posted 07 April 2011 - 02:42 PM
Just helping out this topic....
“articulated kinkeshiâ€￾ - These were part of the Bandai Toy/Candy collection. 1985
“larger than the 4inchâ€￾ – Not only were some a part of the first Deluxe Battle Royal Jikkyou Ring, Kinnikuman & Blocken Jr, Buffaloman & Mongolman, Neptuneman & Sunshine were a part of the ‘The Damage’ type sets. Which was a part of the Bandai Pla Model division. In these sets they gave you stuff to customize the figs. Make them Battle Damage etc.
“colored dekaâ€￾ - If I remember correctly these were made from a more rubbery material. So you can stretch them out. Nobi nobi, so to speak…. Kinda like how you stretched the old Stretch Armstrong. But these Kinnikuman Ultratekkusu went back to shape quickly. (Ultratekkusu-Ultratext, 'texture')
“Reissue Dekaâ€￾ - Were from 1999. 20th anniversary. The GITD was the ‘chase’ Dekakinkeshi
‘Great Muscle Series’ – Correct, only two paired, Kinnikuman & Neptuneman-Kinniku Buster and Kinnikuman & Buffaloman-Kinniku Driver
Edited by Stinger Wolf, 09 April 2011 - 12:50 PM.
#24 Ericnilla
Posted 07 April 2011 - 03:01 PM
Does anyone have a PART-3 Ammonite from stingers list~? ryans list shows Xiamen in the place where Stingers shows Ammonite.
Maybe they made a change~?
Does Ammonite even exist~?
#25 89cpe
89cpe
    sweep the leg
  • 1510 posts
Posted 07 April 2011 - 07:39 PM
Thanks stinger all info is greatly appreciated. Any more you can add would awesome! The colored deka i have are not stretchy but i might just have a different type. Also please let us know about ammomite because he doesnt go with that part hes pictured in. Xiamen comes in the box set for that part. Please any pics you can provide of your collection and checklist would be helpful and cool to see. Thanks
